May 22, 2013, 12:01:24 PM *
Pages: [1] 2 3 4   Go Down
Author Topic: Italian Salesflap  (Read 15922 times)
« on: September 20, 2008, 12:44:40 PM »
3" narrowed adjustable beam, dropped spindles, straight axle, raised steering box, raised center pin, tie rods flipped on the swing lever, notched frame rails.
I'm *guessing* the spring plates are set up between 3.5 and 4.5 degrees, but it's been so lomng I don't really know. I did this one before I started taking notes on every drop job for future reference.
Wheels are 4.5 and 5.5 Sprint Stars with 195/55/15's on the rear and 165/45/15's on the front.
In it's current state "The Smoker" as we call it is just about perfect.
Rides nice, plenty of power with the 2110 and 44's.
However is does smoke like nobody's business...
Once I get the room in my shop, and the time, I'm going to tear the engine down.
My plan is to add some slip in 94's (http://lowbugget.com/pistonpage.html) to bump it up to a 2276cc, swap the 44's out for a set of IDA's put the magneto that I've had sitting in my shop finally in an engine, and do a Porsche center shroud set up.
With more cc's and HP I figure the "junkyard" tranny in it now should come out too.
With that in mind I bought a used Rancho Pro Street tranny from my buddy Steve.
When it's all said and done it should be MUCH more fun to drive.
I'll post up pics here when the work gets going.
« Reply #1 on: September 21, 2008, 07:54:55 AM »
Sure, go to your buddy for the trans.
Build the engine your self. I aint mad... I wouldnt want to help anyway... ;)
I'm guessin, they must have stopped making pallets & then Fed-Ex & UPS must have stopped shipping to Colorado.
Make sure to set the ring end gap on the new top end. I would. I know you build your own stuff, but let me help the smoker get smokin'. Im vet @ this whole smokin thing by now!
Call me, I'll hook U up!  U buy the parts, Ill put it together & do the heads up all sweet.
« Reply #2 on: September 21, 2008, 09:25:58 AM »
The trans came out of my buddies bug. He was running a 2007 cc but stepped up to a 2387 FI Turbo  :o so he needed a bigger trans.
I got his pro street trans for $300 minus the short axles / tubes so I can't complain.
You got a deal on the heads though. I need mine cut for 94's and the valves done up sweet. You're the man for the job.
Once I tear it down you'll be getting a call.
« Reply #3 on: October 08, 2010, 10:03:45 PM »
Wow 2 years have gone by....
 dunno
I pulled the smoker out of hibernation today for this first drive since July 2009...
I really miss driving this thing on a daily basis so I'm finally going to do the "upgrades" mentioned above plus a few others I've thought of.
Steve's old prostreet trans is on the stand right now, HD axles just arrived today so I'll get it together next week and then all the current engine / trans will come out. I'm over the Porsche fan shroud, but may still run the magneto, just because, do a valve job and open up the heads as well then put it all back together.
No time frame as I'll be working on it when there are no customer cars in my shop.
« Reply #4 on: October 11, 2010, 05:38:55 AM »
that bus is just so nice.
« Reply #5 on: October 11, 2010, 02:30:38 PM »
Different wheels, bigger engine, no more smoke, and a better geared tranny will make it even better.
Not to mention new door seals and something to keep the "flap" from squeaking / banging while driving.
I'll be ready for a *real* road trip in it pretty soon!!
« Reply #6 on: October 12, 2010, 01:49:04 PM »
Might have to try those old wheels on a certain camper  thinking
« Reply #7 on: October 12, 2010, 07:46:58 PM »
They fit, but they'll need new chrome / paint for that show machine.
« Reply #8 on: October 14, 2010, 11:01:53 AM »
These showed up today.
Better pics after lunch when I can get them mocked up on the new brakes...
oldeskool65
« Reply #9 on: October 14, 2010, 11:21:21 AM »
 puffin Sweet!
Steve
Online Online
« Reply #10 on: October 14, 2010, 01:27:19 PM »
Only real playas have those wheels right Jay thumbs up
« Reply #11 on: October 14, 2010, 03:46:11 PM »
This is what I'm looking to do.
Since the bus rides so nice as is I wasn't planning on doing the new hybrid spindles, instead a new twist on the old way.
Spacers and caliper mounts, only I needed to do a Wilwood mount instead of 944
(this is about the time my camera took a dump, so the rest are poor quality phone pics  thumbsdown )
I did a quick mock up on a "regular" dropped spindle to make sure things would fit before taking my bus apart.
Things look good. When I get home from AZ. I'll fit them to the bus.
I think those ears need to go Max.......
Here's a couple without the rear of the rim for a better idea of what's going on.
Rears are  no brainer. I'm running T3 brakes now, so I'll swap the wide 5 lug out for a set of Porsche drilled 4 lug units. Done deal!
« Reply #12 on: October 14, 2010, 09:29:54 PM »
A set of these should be here when I get home too!
Online Online
« Reply #13 on: October 15, 2010, 06:30:16 AM »
Bad Ass
« Reply #14 on: October 26, 2010, 12:36:50 PM »
With a wrong year front disk kit purchased by a customer (see here for front end differences... http://lowbus.com/BB/index.php?topic=801.0 )
I have found some time to get on with the install this week.
In the meantime another hybrid set up is ready to go out!
« Reply #15 on: October 27, 2010, 02:04:37 PM »
4-lug?  thinking
« Reply #16 on: October 27, 2010, 03:18:29 PM »
4 lug T3 drums re-drilled for Porsche pattern.....
« Reply #17 on: October 27, 2010, 04:28:40 PM »
 Badass,
 Are those Delrin bushings for the beam arms?
« Reply #18 on: October 27, 2010, 09:31:47 PM »
Badass,
6" bug beam in the works for a customer's car.
Good eye!
« Reply #19 on: October 29, 2010, 02:44:18 PM »
Got my wheels together before lunch today.
Working on the disk conversion right now. If all goes well (no leaks on the tires) I'll be on the ground tonight.
I plan on running 165/50's but I donated my set to the Hostile 15 window so I'm temporarily using the 165/45's that were on the Salesflap.
With 2 pc wheels swapping tires is pretty easy.
Here's a quick how to....
Here's what you need.
2 pc wheel, tire, tube, WD-40, blunt tool, impact gun, tire filler, hemostats
Tube into tire, add a little air to fill it out.
Fit the front of the wheel, hold the valve stem with the hemostats.
Lube the tube
Fit the rear 1/2 of the wheel using the blunt tool to keep the tube from being pinched.
Use an impact to torque the nuts down to MAXIMUM pressure
Not really!
I actually worked my way up to 50 ft/lbs with my torque  wrench. If I get no leaks I'll pull the nuts off one at a time for some lock-tite then get them on the spin balancer.
king_tuk
« Reply #20 on: October 29, 2010, 05:20:38 PM »
why couldn't you use a sealant on the flat parts when bolting it together and a bead of sealant around the joint on the inside of the rim like a they do for 3 piece wheels?
« Reply #21 on: October 29, 2010, 08:50:44 PM »
More info on that please. I'm not a BIG fan of running tubes, but anyone I talked to told me that was the way to go with these.
« Reply #22 on: October 30, 2010, 11:32:58 PM »
Caliper mount on
When doing a Porsche conversion without hybrid spindles the grease cap need to be made "taller" to fit the stock bus spindle.
Here''s a before shot
I made this tool to press the caps to the needed height
After shot
I found out the hard way if you stretch the drivers side (with speedo cable hole you end up witha hole that is too big for the cable.
So instead I use passenger side caps and then drill / square file after they are stretched
Rotor / hub assembled. Rotor painted black to avoid rust issues down the road. Spacers installed, bearings greased and set in, jam nuts set and lock tabs bent.
Stretched cap with new speedo cable hole.
Caliper mounted, speedo cable clip installed. ready for a bleed and then mount the wheels
« Reply #23 on: October 30, 2010, 11:40:27 PM »
With the front done I've decided to go with adapters in the back instead of switching to Porsche pattern T3 drums.
This will push the wheel out farther and fill up the wheel well. When my rear tubes get here next week I'll get on that.
Until then, this is all I have.....
Red stripe, Red caliper........... what??
Yeah all the pictures are from one side. It was pouring here today so I rolled it out, took these pics and rolled it back in.
More sun when I have 4 matching wheels, and some sun....
« Reply #24 on: October 31, 2010, 06:49:29 AM »
 thats awesome.  thumbs up thumbs up
« Reply #25 on: November 01, 2010, 08:31:15 PM »
Im likin the new look Greg thumbs up
vwfreak62
« Reply #26 on: November 02, 2010, 02:18:06 PM »
If you were in Az you wouldn't have to worry about that wet stuff.
you did it again, Porsche pattern 5 spokes front beam....damn good stuff!
« Reply #27 on: November 02, 2010, 02:39:35 PM »
Heading to the blaster to clean up a 2nd set of adapters so I can get the rears on today.
I used the original set on the 15 for spacing today... oops  oops
« Reply #28 on: November 02, 2010, 07:25:59 PM »
All four done........ where are those caps?
 biggrin
Online Online
« Reply #29 on: November 03, 2010, 06:30:31 AM »
Pages: [1] 2 3 4   Go Up
