« Reply #120 on: April 12, 2011, 07:45:56 AM » |
Reply
keep making progress on my car Greg
« Reply #121 on: April 12, 2011, 08:39:03 PM » |
Reply
Made some room for you Greg.
« Reply #122 on: April 13, 2011, 12:05:24 AM » |
Reply
Thanks for that Jeff! Hello old friend. Nice to see you again.
« Reply #123 on: April 13, 2011, 12:18:20 AM » |
Reply
So getting that tunnel trans took some "massaging" of the 356 sheet metal, as well as some 'clearancing" to the trans, but I got it in! By the time I was done with the rest of the trial fitting it was too dark for pics, so I'll jump right to the goods. You may remember the engine in the back ground from my "new transmission" picture.  That's my new power plant. It's probably a bit over kill, but the good stuff always is. Here's the specs: freshly assembled 2332 with dyno time only as41 case std bore and drilled for full flow. 84 Bugpack wedge mated crank type 4 center VW rod lightened flywheel chromoly gland nut 4 puc disc Kennedy stage 1 p/plate clearanced engle FK89 cam straight cut cam gears scat lifters eagle 5.7 rods 8mm chromoly head studs 94mm weisco pistons w valve relief's cut 94mm Jaycee long barrels Melling high volume oil pump Gene berg 4qt oil sump Jaycee oil filter bracket and mount System 1 oil filter stainless braided oil lines and head drain back lines Jaycee crank trigger kit copper head gaskets Super Flo heads ported by heads up performance 10-1 compression 48mm stainless intake valves 40mm stainless exh valves k-800 springs scat 1.45 ratio rockers Jaycee chromoly push rods Jaycee push rod tubes match ported intake manifolds for 48mm IDA and a couple shots of it on the dyno at Jay Cee The first few pulls got between 198hp - 204hp @ 6000rpm before jetting and *really* tuning the carbs. Jack asked me if I wanted drive-ability or max hp. I want drive-ability so he tuned it accordingly. He figures 210hp + @ 6500rpm with a redline up near the 8000rpm mark
« Reply #127 on: April 13, 2011, 01:53:51 AM » |
Reply
With the trial fitting done I'm going to adjust the suspension up a bit (I obviously didn't get the spring plates right after I lengthened and notched them) then it's on to sorting the oil cooler / filter placement as well as a breather box of some sort and running a new fuel system. Fitting up the shroud and other sheet metal will be after that. Then it's all coming back out some I can detail / paint / wrap it before final assembly and smokey burnouts!
« Reply #128 on: April 13, 2011, 05:43:41 AM » |
Reply
Nice firewall cover. Never seen anything like it. Is it a Porsche thing or custom?
« Reply #129 on: April 13, 2011, 08:16:58 AM » |
Reply
Looks like its gonna be quick that's for sure!
« Reply #130 on: April 13, 2011, 08:20:17 AM » |
Reply
Looks awesome Greg.
quintin
Offline
« Reply #131 on: April 13, 2011, 09:08:52 AM » |
Reply
Are you gonna lose that awesome stance now that you have a monster sump ready to smack the ground? That motor is ri-damn-diculous
« Reply #132 on: April 13, 2011, 09:22:39 AM » |
Reply
The stance will be fine. I'll change to a thinner sump if need be. I'm not driving around in "ass in the air" Cal Look car that's for sure. I think a combination of me goofy when I put the spring plates back in, and the new engine being MUCH heavier have the ass a bit lower anyway.
That's today's mission
« Reply #133 on: April 13, 2011, 10:23:57 AM » |
Reply
That's a Porsche thing.
« Reply #134 on: April 13, 2011, 07:23:52 PM » |
Reply
Looks like alot of fun bro. I hope that tranny can handle it.
« Reply #136 on: April 14, 2011, 12:30:34 AM » |
Reply
Mike at Rancho told me the Pro Street plus was good to 250hp. When I told him it was NOT going to have slicks he told me "you'll be fine". I'm *pretty* sure he know what kind of stupid stuff I do and would have up-sold me to a better box if I needed it. Speaking of that, here's the tranny specs. 3.88 Super Diff Aluminum Side Cover Welded 3-4 Hubs Hardened Keys Stock gearing Super Beetle main shaft HD axles
« Reply #139 on: April 14, 2011, 06:57:40 AM » |
Reply
I still have the message on my white board in my office. It has been there for 2.5 years now
« Reply #140 on: April 14, 2011, 06:56:41 PM » |
Reply
I made it easier for you to sit next to me today...  Still needs some cleaning, but then again the front has been run into a curb, so    At some point I'm going to have the bottom recovered to match the backs (which I stole off the OG buckets) so it all matches.
« Reply #141 on: April 14, 2011, 06:57:45 PM » |
Reply
Sump clearance is no longer an issue either.  We nick-named this engine "The Octopus" because there are oil lines , drains, etc. running everywhere. I'm going to re-route / remove some of that when the time comes, as well as relocate that filter.
« Reply #142 on: April 14, 2011, 06:59:19 PM » |
Reply
I figured new front bumper brackets were cheap enough so I ordered a set of them today too. Once I have them i'll fit the front bumper to the car and re-paint it.
Then it goes to the back burner again while I get the Smoker back on the road.
« Reply #143 on: April 14, 2011, 07:00:58 PM » |
Reply
That bench seat looks awesome Greg!
« Reply #144 on: April 14, 2011, 07:03:38 PM » |
Reply
Thanks.
« Reply #146 on: April 14, 2011, 07:32:54 PM » |
Reply
I luv this ride...Looks real good Greg
« Reply #147 on: April 14, 2011, 08:08:56 PM » |
Reply
I picture phills rolling bitch in that thing around the host hotel at classic
« Reply #148 on: April 14, 2011, 08:59:46 PM » |
Reply
That's gonna be one mean son of a bitch Greg and that front seat is bad ass too. Very nice.
« Reply #149 on: April 14, 2011, 09:08:51 PM » |
Reply
You mean in the middle, right? I'm sure the engine will be too much Jeff, that's the plan.  If you want to go BIG let me know. I have the means to make that happen now with *very* little waiting once we have all the parts on hand. Thanks Rich, it'll be OK for a driver, but not for jack stands and mirrors. Kobus hit me up yesterday about shooting it for Air Mighty and another Porsche mag he is doing work for once I have it running. I told him I'd need to do A LOT of work to it before it was magazine ready. His reply was something along the lines of, "it's perfect now". So I guess that sums it up.
