« on: August 15, 2008, 08:51:39 PM » |
Reply
First I checked the angle og the steering column  Then unbolted the box and dropped it out  Transfered the angle to the frame   THEN CUT IT and mocked it up  this is underneath to show how much clearance it gave me  And started boxing and gusseting the raise I fucked up and got 1/4" plate so it takes longer to cut
« Reply #1 on: August 17, 2008, 07:47:45 AM » |
Reply
Nice job, :)
crazyeyes
« Reply #2 on: August 17, 2008, 08:52:29 AM » |
Reply
dont forget to notch your pedal plate too.... i didnt do that on my sc and i couldnt stop once... ;D
« Reply #3 on: September 04, 2008, 12:56:29 AM » |
Reply
looks good!! thats a ballsy job, something i need to do but won't probably
« Reply #4 on: December 08, 2008, 08:38:38 PM » |
Reply
I got your balls bitch ass nukka ;D
« Reply #5 on: January 03, 2009, 08:43:50 PM » |
Reply
do you have a pic of the final set up?....I went striaght up 1" with mine then cut 7/8" out of the column
« Reply #6 on: January 04, 2009, 12:18:07 AM » |
Reply
You want a pic with the box bolted in and where the steering wheel sits? I can take on tomorrow I cut 1.5" of the column. Still havent fucked with the floor though
I think going straight up helps a little with the floor
« Reply #7 on: January 04, 2009, 04:01:05 PM » |
Reply
yeah I was wanting to see how it affected the floor....
« Reply #9 on: April 03, 2009, 07:29:47 PM » |
Reply
what's the most you can raise the box without fucking with the floor?
« Reply #10 on: April 03, 2009, 08:44:51 PM » |
Reply
Not sure
I think if you go straight up you can go a little more but still less than 2", Maybe 1.5" (MAYBE)
« Reply #11 on: April 04, 2009, 08:51:36 AM » |
Reply
If you go straight up the angle of the steering column changes.
« Reply #12 on: April 04, 2009, 02:03:22 PM » |
Reply
Just means it's easier to rest the elbows on....
« Reply #13 on: April 04, 2009, 09:02:25 PM » |
Reply
Just means it's easier to rest the elbows on....  and for us fat guys it puts the steering wheel farther into your gut!
IN2RUST
Offline
« Reply #14 on: April 07, 2009, 07:55:28 AM » |
Reply
^^^LOL, I was thinking the same thing...
paule
Offline
« Reply #16 on: June 12, 2009, 10:39:16 AM » |
Reply
you can raise the box about 35mm before you have to modify the floor. i just did mine and the pitman is just barely touching the floor.
« Reply #17 on: June 12, 2009, 11:05:49 AM » |
Reply
straight up or at an angle?
paule
Offline
« Reply #18 on: June 13, 2009, 05:25:02 AM » |
Reply
On the angle. Im goin in to shorten the column today. im stoked, i'm gonna drive all day tomorow when i get it finnished.
Gadget Boy
Offline
« Reply #19 on: August 18, 2009, 09:31:11 AM » |
Reply
Whats intersting is here in the UK people are starting to raise th esteering boxes on baywindows now too
« Reply #20 on: August 18, 2009, 09:41:12 AM » |
Reply
Post up some pics / details.
StanceMastaJ
Offline
« Reply #21 on: August 18, 2009, 09:03:45 PM » |
Reply
Greg's not fat. He's "big boned".
On the steering box raise... it looks better all smoothed out...but it weakens the welds, unless there's tie-in gussets inside the rail pieces. I recomend just welding it hot and leaving it.
« Reply #22 on: August 18, 2009, 09:24:24 PM » |
Reply
I have no problems grinding my welds flush. Not once have I had a weld brake or even crack. As long as you get good penetration you are fine. I have built pretty big structural pieces for work (ironworker) and have never had a problem Fact is I over built the box raise. I understand what you are saying but I have complete confidence in my welds
Gadget Boy
Offline
« Reply #23 on: August 19, 2009, 07:46:51 AM » |
Reply
Post up some pics / details. T2D have done it on the latest slammed rat baywindow they've built If i can find some photos Greg I will get em up 4 you guys .
StanceMastaJ
Offline
« Reply #24 on: August 19, 2009, 11:38:35 AM » |
Reply
:biggrin:Sweet...just lookin out.
« Reply #25 on: August 19, 2009, 02:27:59 PM » |
Reply
Yeah I appreciate it and it is good advise for someone who may be a little weary or worried about the welds being strong enough.
