$db_character_set = 'utf8'; ?> 66' hard top sedan
January 22, 2019, 04:54:29 pm *
Pages: [1] 2  All   Go Down
Author Topic: 66' hard top sedan  (Read 20134 times)
RAGTOPDAVE
« on: November 23, 2010, 10:54:43 pm »
Removed the body off the pan, both halves were quite rusty, with the passenger side being the worst, large hole in the rear section.
Not having the proper tools for the job and this being the first time at this, things are going good yet slow. managed to get both halves removes and new pans are prepped to go in. practicing the old welding skills.
This is my son's car, a good project for the both of us, learning as we go!!!!
« Reply #1 on: November 24, 2010, 03:02:59 pm »
Nice.
Post up some pics.
I was going to offer some pan sections, but it sounds like you have that covered.
RAGTOPDAVE
« Reply #2 on: November 24, 2010, 05:02:00 pm »
I clicked the REPLACE image icon yet it wont let me post the pics?
« Reply #3 on: November 24, 2010, 08:34:18 pm »
You have to host them some where than add them. Hence the new "bug" section in the gallery.
Here's a thread I posted awhile back explain how to do it.
http://lowbus.com/BB/index.php?topic=483.0
RAGTOPDAVE
« Reply #4 on: November 25, 2010, 12:37:21 pm »
RAGTOPDAVE
« Reply #5 on: November 25, 2010, 12:39:36 pm »
JahBug
« Reply #6 on: June 23, 2011, 06:06:10 pm »
 The pan haves welded and almost down to bare metal.
JahBug
« Reply #7 on: June 23, 2011, 06:08:22 pm »
 Painted!!
JahBug
« Reply #8 on: June 23, 2011, 06:14:30 pm »
 Sound deadening.
JahBug
« Reply #9 on: June 23, 2011, 06:17:09 pm »
 New Duel Circuit Master Cylinder, Brake lines and shoes. Old or original back plates.
JahBug
« Reply #10 on: June 23, 2011, 06:23:56 pm »
 Transmission Cleaned and painted. New Mounts and boots.
JahBug
« Reply #11 on: June 23, 2011, 06:27:41 pm »
 Front end stripped and cleaned to metal.
JahBug
« Reply #12 on: June 23, 2011, 06:29:16 pm »
 Painted a old Ford White.
JahBug
« Reply #13 on: June 29, 2011, 06:17:00 pm »
  Pressed the ball joints in today and got one set of torsion leaves in. Is there any tricks to doing this with the bearings steel in the beam?Huh? It was a pain in the but to line them up with the adjuster. Thanks to Dave it only took like 2 hr banghead
« Reply #14 on: June 29, 2011, 10:30:40 pm »
Taper the leading edge of them.
Do it WITHOUT the arms on.
Install them in a such a way that the last one you install is NOT on the outside but rather on the inner part of the stack.
RAGTOPDAVE
« Reply #15 on: July 02, 2011, 08:23:18 am »
thanks Greg, the torsions went in easy and in much less time with your input thumbs up
JahBug
« Reply #16 on: July 02, 2011, 05:44:20 pm »
 Almost done with the beam! Might Have a rolling chassi next week  biggrin Thanks Greg, the torsions were so much easier when starting from the outside to in. Thanks!!!!!
« Reply #17 on: July 05, 2011, 08:20:43 pm »
I'll ask because I think I am looking at something weird here.
Why are your adjusters mounted on he bottom of the tubes?
JahBug
« Reply #18 on: July 06, 2011, 08:30:17 am »
 Its a CB Performance Beam that I believe has a poor design Huh?/ thinking When the beam was in the car the bottom adjuster would hit the road on uneven surfaces and bumps. It ended up grinding the bolt down. Here is a pic off the internet, it looks like the adjusters are in the same spot to me.??
« Reply #19 on: July 06, 2011, 09:50:04 am »
Weird.
I've never seen them welded in that spot before.
JahBug
« Reply #20 on: August 06, 2011, 07:15:12 pm »
I knew the right side heater channel had some rust but when I really checked it out I decided patching just was not going to do it. So I opted to replace it entirely.
JahBug
« Reply #21 on: August 06, 2011, 07:22:01 pm »
So after after a long day in the garage, with the step dads help, the heater channel is in. The after market channel did not line up very well so there was some trimming and banging around to get the bolt holes in the right spot. banghead The worst part is that it came with a twist in the channel that was a real pain in the ass. But satisfied at the end of the day. Not with the channel though there must be some one that makes a better one!!
JahBug
« Reply #22 on: November 03, 2011, 07:59:14 pm »
Got Busy with work but I have been doing some things lately. The PO had made the radio hole bigger but I felt like "going going back back to OG OG" Biggie Smalls reference.
JahBug
« Reply #23 on: November 08, 2011, 08:40:52 pm »
The last few days me and Rag top Dave have been going hard. The goal was to get the inside,the trunk space, and the fenders in epoxy sealer and then a filler primer.
JahBug
« Reply #24 on: November 08, 2011, 08:45:56 pm »
When we striped the fenders we were in for a big bondo surprise  thumbsdown we filled the millions of small bumps and dents and just crap. There was one large dent in the rear right fender that I banged out and then added bondo. It would have been easier to bye new fenders but what is the fun in that Huh?
JahBug
« Reply #25 on: November 08, 2011, 08:51:13 pm »
We striped cleaned,did a rust converter, cleaned and sanded again and finally we were ready to mask and do some painting after two days.
JahBug
« Reply #26 on: November 08, 2011, 08:54:10 pm »
Epoxy sealer in the home made ghetto booth.
JahBug
« Reply #27 on: November 08, 2011, 08:56:52 pm »
And then the filler primer.
« Reply #28 on: November 08, 2011, 09:22:37 pm »
very nice work.
« Reply #29 on: November 09, 2011, 05:28:51 am »
Yeah, looks good.
I like your set up there.
Pages: [1] 2  All   Go Up
